Help with a D-21
Wendell,W.N.H. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wendell,W.N.H. Quote  Post ReplyReply Direct Link To This Post Topic: Help with a D-21
    Posted: 24 Jul 2023 at 9:06am
I have a 1966 D-21 with a non- turbo engine. Has been running fine, but now will run for a few seconds then quit. I replaced the inline filter under tank (twice) and spin on is new. I pulled off the spin imediately after it quit one time and it was full of fuel. I checked power to the shut off on pump and it is getting power while key is on. Air filter is new. It will start right back up after it quits. Does this mean my problem is with the injection pump? The pump is a Stanadyne, DCGFC629-2AG. Thanks for any help
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2023 at 11:24am
flex ring inside pump is breaking down and the pieces are plugging the return fitting in top cover of inj pump. You can take the fitting out, remove the ball and it should run, this is a temporary bandaid. It will need serviced soon. You can verify this by loosening the bolt on side of pump with 1/2" wrench, and let the fuel leak out the side. It stays running it confirms the return is plugged making it lose power and dying.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2023 at 11:38am
...it will not get better,only worse. Time to start getting educated on steps for pump removal/installation. The rebuild should last longer than you.
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2023 at 4:11pm
And one of those that answered your question (injpumpEd) is who can rebuild it for you Den
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts.
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2023 at 5:57pm
Hi Wendell, Den is right you want Ed to do it. He's done two of my tractors, and injectors. He will talk you thru removal. and installation.  Tim
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2023 at 6:00pm
Yep,Ed gets my vote also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2023 at 9:48pm
I have nothing but good things to say about Ed’s work. Right man for the rebuild for sure.
