D17 hydraulic questions
Wieks46 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wieks46 Quote  Post ReplyReply Direct Link To This Post Topic: D17 hydraulic questions
    Posted: 24 Jul 2023 at 8:43am
Recently acquired a d17 series 3 it has 1 hydraulic port on the rear of the tractor my question is do I need a hydraulic valve and lever coming off of that port to run a cylinder or is there a lever already on the tractor that I'm not understanding also I have been seeing the d17 hydraulic pressure might be to high for some cylinders is this true on series 3 as well for reference trying to lift a john deere 1209 haybine thanks
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2023 at 9:12am
Although not an AC tractor, we had a IH haybine that was equipped with a hyd cylinder that was one hose. Raised and lowered just the same as our NH that had a two hose cylinder, just moved the hyd lever to the ‘float’ position, and all was good. If I recall the D17 of that vintage was a ‘high pressure/low volume’ system. You may need to get a hyd cylinder designed for those systems, but a ‘one-way’ or one hose cylinder should work just fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wieks46 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2023 at 9:36am
Ok thanks I'm beginning to think I'm missing the hydraulic operation valve and lever to control the cylinder also wondering if that 1209 haybine is right for me seeing how it has a john deere cylinder on the rear to lift instead of a tie rod Style don't understand enough about the high pressure low volume system enough
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2023 at 10:21am
The lever below the traction booster lever is the hydraulic lever. Located to the left of the steering wheel. That raises the 3 pt arms and the outlet. Once the arms are up it will lift the cylinder that’s plugged in
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2023 at 1:23pm
Raise the lift arms and tie, wire or chain them up so when you want to raise the header on the haybine it will raise immediately. I've used all kinds of cylinders on haybines with a D17 ser.3 and never had a problem with the high pressure/low volume system harming the cylinder. 1 hose is all you need. Just install vent plug in the other port.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2023 at 8:53pm
Use the smallest cylinder that will lift your load. Smaller the cylinder the faster up and down.                   MACK
