Power steering fluid |
only AC orange
Joined: 06 Dec 2014 Location: Eastern Indiana Points: 554 |
Topic: Power steering fluidPosted: 21 Jul 2023 at 11:22am |
What is the correct power steering fluid for D-15, series 1?
Eric B
Joined: 09 Feb 2012 Location: British Columbi Points: 993 |
Posted: 21 Jul 2023 at 11:47am |
I like using synthetic 10W 30 engine oil in my D14 power steering, much because of our cold winters. My power steering has improved immensely from a leak by using Lucas power steering stop leak additive.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 88671 |
Posted: 21 Jul 2023 at 12:50pm |
you can use Power Steering fluid from the Auto Store... Or older versions of Automatic Trans Fluid Type A, F, Dextron 1-2-3 ..( I would not use the new MERCON LV or other synthetic with too many addatives- might effect old seals)..... or you can use Universal tractor Fluid ( UTF)..
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5250 |
Posted: 21 Jul 2023 at 1:29pm |
I put 10W-30 in my series 1 D17. Have also drained and used Universal hydraulic fluid to see which worked best. Both work fine. Series II went to transmission fluid as Steve stated.
Edited by AC720Man - 21 Jul 2023 at 1:30pm |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54468 |
Posted: 21 Jul 2023 at 4:32pm |
Original owners manual stated 5W20, Non detergent. IIRR...
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7540 |
Posted: 21 Jul 2023 at 8:39pm |
ATF or hydraulic fluid. ATF is better in cold weather, but will leak if your seals are weak because the oil is thinner. I run ATF in all of mine. No problems - all my seals are good.
