912 allis does wheelys
Fed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fed Quote  Post ReplyReply Direct Link To This Post Topic: 912 allis does wheelys
    Posted: 19 Jul 2023 at 1:38pm
When I leave the clutch out, it doesn't catch gradually, it grabs all at once and you do a wheely. I have to use the tractor in low range and have the throttle very low to keep from lifting the front tires off the ground. I've replaced belts, greased everything, and made sure all the pulleys are moving free. I checked all the fluids in the transmission and rear end. I can't figure  out why it's grabbing. Anyone with a suggestion?
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2023 at 2:34pm
Are all the belt guides in place and adjusted right? And then need correct width & length belt. Should be able to release clutch without jerking! Need a manual to check all the hi low range adjustments.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2023 at 8:48pm
Lift the seat up with it in neutral and operate the clutch and watch how the idler releases. Maybe you can see where it’s acting up.
