needed grease cap for 82S mower
bill5308 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill5308 Quote  Post ReplyReply Direct Link To This Post Topic: needed grease cap for 82S mower
    Posted: 18 Jul 2023 at 1:29pm
I need to replace a grease cap my 82S mower.  Can anyone point me in the right direction.  I tried ebay.
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2023 at 1:50pm
all the 80 and 82's should be the same.
Edited by Macon Rounds - 18 Jul 2023 at 1:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2023 at 1:52pm
Welcome to the forum. Which cap are you talking about
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2023 at 1:55pm
most grease caps are a STANDARD size... like bolts... You measure the HOLE your trying to put the cap in, and order that size... You can GOOGLE a size to get the right one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2023 at 2:30pm
82S is a Side mount mower.
no wheels on those, so I assume it's the cap for twin Wheel drive.....
Edited by Macon Rounds - 18 Jul 2023 at 3:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2023 at 2:35pm
I have a 82S and I don’t recall a grease cap on mine? I’m not close to it to take a look but if memory is correct there is a expansion plug on the end of the drive housing? Are you referring to it? Or are you referring to where you refill it with oil? Location would help and a picture would be even better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2023 at 4:01pm
I meant the top outer ones 804505 or lower inner 804506.
The top outer is still available through agco.
The lower inner we have.
If you don’t have a parts guy. We can probably help you on both
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2023 at 9:21am
If it is the cast one pictured with the zerk, which it should be for the 82 series, I have them...$25...Thanks...Dale
Orangereborn
Dale Schafer
964 192nd Ave
New Richmond, WI 54017
715-247-3079
Cell 715-781-2055 Text
Orangereborn@hotmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill5308 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2023 at 12:34pm
can you give me a price on the rear outer bearing cover?
bill casey
bill5308@aol.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2023 at 8:37pm
What number you looking for
Edited by Mikez - 19 Jul 2023 at 8:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill5308 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2023 at 9:28am
part # 8
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2023 at 9:48am
