Failed 210 overhaul revisited…..again
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Topic: Failed 210 overhaul revisited…..again
    Posted: 16 Jul 2023 at 11:48am
Thought and discussions?
1968 D15D,1962 D19D
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2023 at 12:48pm
It's been interesting following this rebuild. A likely reason the new piston  is built heavier in some areas is that the same basic engine design was used for another 15 years with mush higher horsepower ratings. Almost 20 years ago I had an almost immediate engine lock up on a fresh rebuild in a D21. Ring gap is the thing to watch for! Nephew has an engine machine shop and is meticulous. Always checks end gap and recently discovered a tight one in a JD 9L rebuild kit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2023 at 2:22pm
A couple of thoughts as this issue keeps going on: #1. Their 210 engine had an original piston that was scored. WHY was it scored ?? Why aren't we concerned about it??   #2. The only 426 engines I've really ever had a piston scoring issue with (for the sake of scoring pistons) is any of the non-piston cooled engines (D21-210-220 and 7030). The same piston/sleeve combo is used in piston cooled engines and hasn't ever really been an issue for me. What would that tell you??  Oil cooled pistons run cooler and don't swell up as much as non-piston cooled pistons.  #3. I know a lot of time and effort was put into warming and cooling pistons and measuring skirt diameters and comparisons of new aluminum to old aluminum. I don't believe it is still quite the same as a piston in actual operation, because under full load/HP output the piston top temperatures are over 1,000 degrees F. I'm not saying the skirts are 1,000 degrees, but I am saying things could be hotter than tested and again a piston cooled engine will be COOLER because of the oil spray bath designed to take away that heat.  #4. Lastly. I can't say I've ever overhauled a single one of these engines that were "worn out" from excessive piston to sleeve clearance. The overhaul was due to scored pistons/sleeves or too much ether used, broken #2 rings or a dusted engine which usually failed the rings or ring lands. So, all the focus on having too much skirt clearance being a terrible thing isn't really worth talking about. Of course, this is just my opinion from decades of fixing these engines. At this point, I really don't care what anyone does. You just live with the results however they turn out. 100 hrs of run time isn't a big test. 1000 hrs at 100% full load and an occasional loose set of fan belts or a dirty radiator that takes the coolant temps to the red line a time or two would be more of a test, don't ya think ?? Because that's what really happens in the real world of farm tractor engines.     EDIT:  I doubt that the old pistons had an "oval" piston pin bore due to their age. Later on when the 7080 engine came out, A-C went to a piston pin bore that was bigger side-to-side than it was top to bottom. This allowed for piston pin flexing without putting undue stress on the piston body itself. Wonder if the new piston has this feature??  it should have because it was a running change/improvement to the piston design. Don't remember for sure but I think it was .0005" to .0010" wider than top to bottom dimension.
Edited by DrAllis - 16 Jul 2023 at 6:39pm
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2023 at 9:44am
I don't want to be the genius guy who calculates the bumble bee can't fly, but...
As I read their data, the piston expanded .008" from room temp to 300 degrees.
Considering 300 degrees the operating temp of the piston skirt. Seems reasonable.
Missing is the new diameter (expansion) of the sleeve when up to operating temp.
What could this be? Assume the sleeve gets to 200 degrees, the answer is about
.0033 expansion. (6ppm/deg.F, 130 degree rise,  4.25" diameter).
So, .0035" (starting clearance) + .0033" sleeve expand-.008 piston expand=-.0012"
negative clearance at operating temp. Interference, the engine will melt!
Assume we want to operate with .0025" operating clearance (my guess), we should have started with .00072 piston to sleeve clearance. Now who told us that?
However, the piston mfg of these parts say .0035", I see tones of similar numbers
(the net, YouTube...) for car engines. I don't know.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2023 at 9:46am
and, Dr. , one always see's "the tractor is set a XXX HP" which is usually way over 10% above the OEM setting.  There is a reason an engine is set at a specific HP - go over that and sometimes it works, sometimes not.  The Harvey plant set the new engines at 10 % over rated hp and ran at 100% load.  They determined wear would rack up at a factor of about a 1/3 more than the average 80% load a tractor usually runs at - thus saving time on the dyno to determine if the engine meets engine life requirements.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2023 at 12:04pm
I'm surprised they didn't heat a sleeve up and see if it too grows slightly. I am sure it doesn't stay the same size.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2023 at 2:32pm
I'm a jack leg but just a thought were the sleeves in spec to begin with?
