G fuel bowl to carburetor leak
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Topic: G fuel bowl to carburetor leak
    Posted: 10 Jul 2023 at 6:42pm
Still piddling around with the little G carburetor. The fuel bowl is directly in front of the carburetor and is basically attached by a small treaded tube. No flare or anything. What would you put on it to stop the leak? Some say Teflon tape will disintegrate after time and it's after the filter. What would you all suggest? Thanks in advance, Ryan
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2023 at 7:39pm
I like “GASOILA”, it’s made for gas
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2023 at 7:55pm
I'm not familiar with that. Time to Google!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2023 at 8:46pm
THREAD PASTE... some is made of Teflon (PTFE) and should work, .... the OLD STUFF was oil base and resistant to  gasoline / oil / water..
Will Teflon tape stop a gas leak?
What is Teflon Tape Used For? Standard PTFE tape is quite versatile and is used to seal water, gas, and air from leaking through threaded connections, most effective on high-pressure lines. However, there are also specialty thread seal tapes geared towards a specific task or need.
Edited by steve(ill) - 10 Jul 2023 at 8:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2023 at 7:26am
Megaloc, get it at Menards, good for anything a standard professional will need , short of Nasa or hospitals. Good for any pipe or for what goes through it.
Edited by Pat the Plumber CIL - 11 Jul 2023 at 7:27am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2023 at 11:44am
I've been using Permatex high temp thread sealant for decades. Never had a problem with it. I don't like to use Teflon tape especially in fuel systems. To much of a chance that stuff could break off and get into the fuel system and cause an issue. Just a personal preference. The Permatex P/N is 59285. Heck, you can get it at Napa......  Thumbs Up
Steve@B&B
