WD45 Motor Problem
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Motor Problem
    Posted: 09 Jul 2023 at 7:12pm
Just bought a nice looking WD45,power steering,57 model,4 bolt WF,new tires all around.Here is the problem the motor turns over hard even on 12V battery plus a big jump box,seems to have too much compression or other issue.Supposedly was rebuilt about 4 years ago,all this from the seller which wasn't the person who was fixing it up.Where do I go from here with it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2023 at 7:36pm
So, attempt to run a compression test with all spark plugs removed, throttle wide open and a battery charger on the battery.   125 psi is WD45......145 psi is D-17 compression.......170psi  or more is 170/175 compression.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2023 at 7:47pm
Does it turn over hard with the spark plugs removed? Maybe not enough bearing clearance?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2023 at 8:00pm
Turns over fine with no plugs
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2023 at 8:29pm
I've built several pulling engines in that chassis with 350+ cubes and 260 psi compression and always got them to start with a healthy 6 volt WD-45 3 bearing starter on 12 volts.    3 brg and healthy is the key along with large enough battery cables.
Edited by DrAllis - 09 Jul 2023 at 8:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2023 at 10:22am
Checked compression No.1 and 3 right a 145.No 2 125 but No.4 is 175 checked and double checked that one.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2023 at 10:51am
Check your starter out for the torque it can produce.
 Check your battery out too... plus check ALL connections and put on heavy gauge wire if you got some cable that is for 12 volt cars already on the tractor.
  Got a WD that turns slow, always turned slow. Dad had it to the repair shop and they checked it out and put a new end cap on and brushes... and still turned slow. Been a slow starter since I can remember it 65 years ago.  Maybe it was just a slow starter to begin with?
 All the other WD's and 45 turned much faster than this one did. Never tried using 12 volts on it since the tractor has a solenoid on it for LP gas. Don't want to burn that bugger out cuzz it probably is obsoleted for the last 40 years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2023 at 11:06am
Most WC's and WD's only had a bushing on each end of the starter armature. A good WD45 starter has a CENTER bearing making it start higher compression engines easier than a two bearing starter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2023 at 2:54pm
So wonder  why the #4 compression is so high?
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2023 at 6:31pm
Ya that is a bit high. Maybe carboned up.  But would have to have a fair bit of stuff in there to bring it to 175???
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2023 at 6:37pm
makes ya wonder if all 4 pistons are the same ?? Wink
after checking out ALL the cable ends... i would try another starter motor, if you have a spare.
Edited by steve(ill) - 10 Jul 2023 at 6:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2023 at 3:19am
Have you tried hand cranking it? If you have ever cranked many of these, hand cranking should let you know if it is turning over abnormally hard.
If the starter is good, it should still turn over ok with 175 lbs. compression. I'm thinking you have an electrical problem.
The first thing I would do is load test the battery. Even with a jump starter, a battery can raise problems if it has an internal problem/
If the battery tests good, I would start looking over the battery cables. Are the battery connections good and clean? Clean up the end of the ground cable and make it is clean and tight. Make sure the cable to the starter is also clean and tight.
Does it still have the pull button start or has someone converted it to a relay (solenoid) start? If it has the pull button, remove it and clean up the inside connections.
If all this is ok, I think it pretty much eliminates everything but a bad starter.
