Rear tractor tires
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Topic: Rear tractor tires
    Posted: 09 Jul 2023 at 4:19pm
18.4x28 rear tractor tires I need a set.Thanks
rtwfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2023 at 4:52pm
Laddy has a nice set
DanielW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielW Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2023 at 9:29pm
I'm guessing from your handle that you're in Wisconsin? I have a used set. They're a far cry from fancy, but they were doing the job before I changed over to 18.4-30's. You're welcome to them, but I'm in Port Hope, Ontario, so probably way too far from you.
Have you considered changing sizes? Depends on how original you want to keep it, but the best thing I did for my 180 was change to 30's. I found a very good set of tires on rims for a few hundred bucks, had new centres made on a plasma table at work, cut out the old centres from the rims I bought and welded in the new ones. They look great, were pretty easy to do, and now I have 'normal' sized tires on there. Some of the puritans here won't like it, however.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2023 at 6:11am
Mine is on my A do no changing them.
