Another DIY tire question
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Topic: Another DIY tire question
    Posted: 07 Jul 2023 at 6:51pm
Managed to ruin the valve stem on a brand new $50 inner tube, bought a valve stem repair patch from Miller Tire then got to thinking, do you put the repair over the old stem or put a patch over that and install it in a new spot?
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2023 at 7:21pm
I usually cut the old stem out of the tube, patch over the hole and install the replacement stem into the tube at the same angle as the one removed but in a different place on the tube.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2023 at 9:35am
That worked, I did double patch the valve stem hole, 1” patch covered with a 2”, just made me feel better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2023 at 9:46am
It has always worked for me in the past and happy you had success!! No problems with double patching at all.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2023 at 4:03pm
Had a tire shop hot patch new valve stems onto tubes for road grader and they went over the old patch area with the new stem - just one area of tube and reused .
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2023 at 12:49am
22 years owning my tire shop, we always put the new stem over the old stem hole.
Edited by 200Tom1 - 10 Jul 2023 at 12:50am
