D17 series I, distributor tach drive hex plug
John Phillis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Phillis Quote  Post ReplyReply Direct Link To This Post Topic: D17 series I, distributor tach drive hex plug
    Posted: 06 Jul 2023 at 10:26pm
Hello,
I am not new to this forum. I lost my password and the email account I used to have is also gone, so I created a new account. Wasn’t sure what else to do.
Anyhow…
I have a very early D17. Serial number is under 1000th one built. It does not have a tach, but I had to get some new gauges and I saw a deal for the 3 gauges I needed, plus a fuel gauge which I don’t need, and a tachometer for $53. So I bought all that. I ordered a tachometer cable and nipple and drive adapter from djs.  On my distributor, which is a power steering tractor, I have a large hex plug on the backside of the distributor drive housing, facing the driver. It looks like that is where the stuff should go, but there is no hole in the hex plug for the threaded nipple. Are those hex plugs available with the hole in them? Or am I trying to install this in the wrong place. I don’t know how to post pictures on here. I used to have a photobucket account for posting but that’s long gone. It’s been at least 10 years since I posted to this forum.
It looks like it would be a real pain for me to drill that hole on center and tap threads in it. I guess I could take it to a machine shop but I am still unsure if that is where it goes. I didn’t get the parts from djs yet, ordered them very recently so I don’t know if I am going about this correctly or not. I guess I don’t really need the tach, but it would be nice to have on the feed grinder and just to keep track of the hours.
Any help would be appreciated thank you
John (formerly John68)
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2023 at 11:14pm
from the AGCO Parts book.... if i am looking at the right thing, it looks like you remove the PLUG and install a NIPPLE ( #16) that is a plug/ threaded nipple combination... i dont see that part number anywhere on a Google Search..
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Phillis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2023 at 11:27pm
Steve,
That’s what I was looking at and now that I’m rereading it, it says, “bushing included” so that must mean that the nipple I bought from djs is just the nipple and doesn’t include the bushing. I guess that a trip to the hardware store might yield a reducer bushing but I am pretty sure most stuff they would sell is NPT, and not NPS, which is probably what it would be since its got a copper crush washer behind it, like an oil drain plug. So I guess I can just take the nipple and the hex plug to the hardware store and see if I can match something up. Seems like I should be able to do that. With my luck, it won’t work, but I will try that first. It’s a pretty good sized plug. I don’t recall seeing anything like that on the shelves before. Maybe if I order it from agco I will get the bushing also.
Thanks for the help, I’ll let you know how it turns out.
John
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2023 at 6:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Phillis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2023 at 9:40pm
Originally posted by Stan R Stan R wrote:
this maybe ???
Hi Stan,
Yes that is the piece I received today from djs. This was my first time putting it in my hands. So what it needs is a hex bushing to thread it into. The hex plug on the distributor housing is not drilled and tapped for it. So that is where I am at.
I haven’t had any luck finding a picture of a d17 with the cable and nipple installed. That would probably help me to at least visualize what it is supposed to look like.
I appreciate you searching that for me! Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2023 at 9:59pm
i would have thought that the nipple that Stan posted would REPLACE the hex plug in the housing ??  How big is your HEX plug ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Phillis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2023 at 10:52pm
Hi Steve,
I was hoping the same thing until I had it in my hand.
It looks like the threads on the nipple are the same pitch on both ends and it is about 3/4”. The hex bushing is 1 1/2” NPS so it is about double the size of the nipple. I’m not sure if the threads on the nipple are NPT since there doesn’t seem to be any copper crush washer, it is hard for me to tell.
I guess I should order the whole thing from agco and see if it includes the hex bushing. I will try the hardware store and see what they have. I guess I should have just lived without the tachometer but once I get something in my head, I can be a bit stubborn about it! Major character flaws!
Thanks again for the help.
John
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2023 at 10:45am
Here are some pics of my early D17 tach drive.  This tractor has the factory power steering.
Edited by Alberta Phil - 08 Jul 2023 at 10:48am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2023 at 10:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2023 at 10:48am
Today it will only let me post one pic at a time!!Angry  Hope these help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2023 at 12:03pm
From Alberta Phil's pictures, These are the 2 parts you need. Contact me if interested
My direct Email address is: the1orangewizard@gmail.com
Edited by PaulB - 08 Jul 2023 at 12:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Phillis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2023 at 12:22pm
Hi Phil,
Yep! That’s what it is supposed to look like.
I really appreciate you taking the pictures and posting them. That is a Really clean tractor. Is that the original paint?!? Looks great!
John
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Phillis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2023 at 12:23pm
Yes! Thanks!
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2023 at 6:53am
I put a tach on my D17. Going from memory here so I might be missing something.
I think I just drilled the big plug and added the nipple from a D14 parts tractor.
The only thing is I don't remember threading the big plug??? I was thinking I machined it and press fit the plug.
That might not be right.
Anyway, I just took a look and the nipple is in the big plug and I know I put the nipple in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Phillis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2023 at 9:36pm
Glad you were able to make it work. I guess my biggest concern is whether I can get it centered correctly without having a lathe to use. I don’t know if it would be that crucial to have it centered 100% but I know that it would be spinning all the time and I don’t want to risk hurting the distributor drive just so I have a tachometer.
Thanks for the advice! I will hopefully have the right parts soon, and I can put the old hex plug on a shelf for when this extremely cheap tachometer fails and I have to remove it LOL
John
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2023 at 1:15pm
John,  here are a couple of pics of my D17.  Yes,it's all original and I bought it from the original owner. It's a factory LP model and was ordered with the 500 loader.  I bought it needing rear tires and a clutch.  After replacing the clutch and rear tires, it's been my main workhorse for many years now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2023 at 8:56am
Again going from memory here so I could very well be wrong, it seems the inside of the plug had a dimple in the center. Obviously that made it simple to get the hole drilled in the right spot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Phillis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2023 at 11:25pm
That’s a really good looking machine! I’m jealous of the originality of it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Phillis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2023 at 11:31pm
Sorry it took so long to get back to you, but you are correct, it does have a dimple! I am going to buy a good used one from a forum member here, if I literally ever get 10 minutes to put an envelope in the mailbox. It’s 12:30am and this is the earliest I’ve been able to get done for quite a while. To make matters worse, this is the worst start to a bean crop I’ve seen since 2010. It’s just going to be one of those years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2023 at 6:10am
Good deal on the tach, not good news on the beans.
We're seeing the same with our beans here too. I was talking to a retired farmer the other day, he says it's because of the wildfires. He had the scientific reason behind it too. From what I've been able to find he is 100% on point in his reasoning.
Edited by Play Farmer - 20 Jul 2023 at 6:12am
