Wanted: Hydraulic drive sickle mower.
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Topic: Wanted: Hydraulic drive sickle mower.
    Posted: 06 Jul 2023 at 9:15pm
Looking for hydraulic driven sickle mower and valving ..
The closer to Pittsburgh Pa. the better.
PM me with your phone number and best time to reach you.
Thanks in advance .
Any brand.
Edited by Macon Rounds - 06 Jul 2023 at 9:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2023 at 8:24am
What are you going to run it with ??   Not sure how many GPM's it will require and an oil cooler too ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2023 at 9:18am
Just the aft section of a rig like this....
I have seen several industrial sickle mower machines that run hydraulicly....
Just need to find a complete unit and non running tractor. 😕
Will be running with a series IV tractor...
But will probably need to to adjust hydraulic pressure/flow independently from tractor RPM so as to sync. PTO driven front sickle and rear hydraulic driven mower.
Will this EVER happen ???
it's on my bucket list.
Edited by Macon Rounds - 07 Jul 2023 at 9:22am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2023 at 12:57pm
Ben... after reading several of your posts, i have determined you have WAY TO MUCH time to think up projects !!!  LOL   Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2023 at 2:42pm
Well, you can't just adjust hydraulic pressure and flow to what you want. Hydraulic pump flow is directly tied to the engines RPM, so that goes down the drain right away.  If the mowers are of the same/similar brand and model the PTO speed/strokes per minute are identical as it is. Just connect with the extended PTO shaft and run them both.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2023 at 6:29pm
thanks Doc.
I'll take that into consideration.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2023 at 6:32pm
Glad you guys are appreciating my posts and pictures....
Gives me more incentive !
Daniel Wills View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Wills Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2023 at 6:46pm
If you need help with transportation services for any of your equipment please feel free to contact me at 667-290-9238
Best
Daniel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2023 at 9:58pm
still searching ...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2023 at 10:26pm
still searching ..
