Updating/Converting to Serviceable Plow Parts
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Topic: Updating/Converting to Serviceable Plow Parts
    Posted: 06 Jul 2023 at 8:23pm
What's the best thing to do with the older CA, WD, 50-series etc. plows if you are going to put one to work? All of the ones I have encountered out this way have 325 bottoms, and you can't find many new parts for them. Both the CA-52 and Snap Coupler model 53 plows I have show some wear, and I do have some rocks around here.
Can a guy convert these to 387 bottoms? It looks like you can still get some aftermarket parts for those.
Or, are you better off trying to convert to some other brand, with bottoms that maybe have even more aftermarkets parts available? (some IH or JD bottom, for example)
I'd be curious to know what some of you in a similar situation have done. Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2023 at 6:26am
All of the Allis Chalmers bottom assemblies are interchangeable, the bolt pattern to the beam is the same on all. You need everything including the frog. Finding complete NOS bottom assemblies might be difficult and used is almost always worn beyond practical use. I've seen many plows with frogs worn so bad the the bolt holes for the shares are worn through.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2023 at 7:20am
I redrilled my frogs to accept 387 shares. Then I bought a bunch of 897 shares becasue you know they will also be discontinues at some point.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2023 at 9:07am
I use ploworx. They can recondition just about any plow part if they don't have the replacement.  I miss the old warehouse in Iowa (bleimers?) they had everything imaginable but they have been closed for a decade at this point
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2023 at 10:24am
i have some AC plowes that may have what you need. located 70 miles east of st. jo.                  MACK
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2023 at 8:33am
Wjohn, those 50 series plows are hard to find parts for. I have several 53's with good parts on them but think mine all have No. 24 bottoms. when you get into the 60 series, parts are somewhat available. Have bought shares for, (I believe) 363 bottoms from Dave the plowman. I could use a couple more and some shins too if I run into him in the future.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2023 at 9:25pm
He should be at Hutch Mike.  Are you coming?
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2023 at 7:42am
I'll be there Ted. Thought Dave told me last year he wasn't going to set up at Hutch going forward?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2023 at 7:48am
Thanks for the different ideas. Sounds like I have a few options. I can probably get by with what is on the plow for the little plowing I may do in the next few years, but at some point I'd like to switch to something where I can replace with new parts as needed.
560Dennis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 560Dennis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2023 at 9:49am
even a number model 4 ?
