Drop axles
jrbynf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jrbynf Quote  Post ReplyReply Direct Link To This Post Topic: Drop axles
    Posted: 05 Jul 2023 at 2:37pm
Been searching and I have not found a good answer regarding why Allis chalmers wc/wd through 185 used rear drop axles vs traditional straight axles. I’m sure this is a complicated answer but from an engineering standpoint what are the advantages/disadvantages/Allis’s reasoning here. Thank you all
DanielW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielW Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2023 at 2:52pm
I've heard a few reasons. My thinking has always been because putting the large bull gear/final drive outboard means the long half-shaft has to take a lot less torque (it's low torque/high speed, unlike straight shafts which are high torque/low speed). Only the short/stubby axle shaft down-stream of the final drives has to take the high torque.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2023 at 3:02pm
buys you more ground clearance too
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2023 at 4:08pm
Better ground clearance for cultivating with the smaller 28" tires?
Allis seems sensitive to cultivating since they have the seats offset to the side for a good view of a front mount cultivator
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2023 at 7:40pm
The UC (U Cultivator) was the first Allis to use that style final drive. Doc has had many posts here supporting the advantage of this design. You could cultivate a crop 3 feet tall, and back then, corn was check planted and cultivated crossways multiple times. No herbicides.
     Having said that, I couldn't imagine pulling into 20 acre field with a mid mount 2 row cultivator, no power steering, hand brakes and a mechanical lift that only worked if the tractor was movng forward.
Leon B MO
Edited by Leon B MO - 05 Jul 2023 at 7:41pm
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2023 at 9:23pm
Cultivated a lot of corn with a WC and 2 row,  lots of sleepless nights after working all day with that.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2023 at 6:56am
...and don't look back when cultivating! I tore out a few feet of corn doing that. Dad would say "I told you not to look back when you were cultivating".
Memories!!! (I didn't say good memories!)
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2023 at 1:01pm
Leon it's all about perspective.....if you'd walked behind  horses for  days to cultivate  what the crude tractor could accomplish in a day,you'd be grinning driving the tractor and thinking how wonderful it was.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2023 at 1:21pm
I remember the first tractor I drove with power steering. I thought it could never get any better than that!
Post Options Post Options   Thanks (1) Thanks(1)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2023 at 6:37am
Leon B MO
 Like IPTOs, Live hydraulics, Power shift transmissions, Cabs with Heat & AC. It was what we had and were grateful to have. As a youngster that was all we did after the corn got a couple inches tall until it was too tall to get through except when making hay. There's now at least a couple of generations that don't have any experience with cultivating all summer and if you told them they had to ride a non cab tractor all day at a creep, you'd never hear the end of the whining.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2023 at 9:02pm
AMEN Paul.  I was one of those that were thankful to leave the horses in the barn and sit on a tractor!  Problem was when you fell asleep.....tore out a few rows of corn, for which I got a royal chewing out.  I missed the horses at first, but as time went on and you didn't have to feed, water, curry or put all that harness on, I got over it.  It was a lot easier putting in gas, oil and greasing and other upkeep.
