WD belt pulley
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Topic: WD belt pulley
    Posted: 05 Jul 2023 at 8:01am
How does it come apart? I had one give to me that's locked up solid. It's been soaking in a five gallon bucket of kerosine and atf for at least  6 or 7 months. Looks like theres a lock ring on the gear side holding in a roller bearing. There is a breakdown in the manual. Any tips?
Edited by exSW - 05 Jul 2023 at 8:02am
Learning AC...slowly
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2023 at 8:28am
this is out of my WC manual, but it's the same assembly
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2023 at 9:57am
That's pretty straightfoward. My manual had a different graphic and no explaination. Thank you.
I don't suppose anyone has the part numbers for the bearings and seals? Or knows where to look.
Edited by exSW - 05 Jul 2023 at 12:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2023 at 12:17pm
71135475 BEARING, ball, outer shaft
70210025 BEARING, ball, inner shaft
70208417 Oil Seal Outer
Bearings should have numbers on them that will work at a parts or bearing store, seal should too
Ford 345C TLB
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2023 at 2:38pm
THANK YOU!
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2023 at 10:57am
I've got it apart,steam cleaned,bead blasted,primed,painted,bearings(sealed) are here and going back together. BUT the interior shaft snap ring must have lost it's temper to the acetalyne wrench. Does it have a part number or spec?
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2023 at 11:03am
Oh, sealed bearing #'s
FAG 6207-2RSR
FAG 6208-2RSR
One was German one was Korean.
$41.00 plus tax shipped. On Ebay.
And I did have to throw the bearings in the freezer overnight.
Edited by exSW - 27 Jul 2023 at 11:06am
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2023 at 1:35pm
I have 2 of these pulleeys that I would sell in Ohio. I think they both need some work from setting around.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2023 at 8:40am
I've been digging looking for this snap ring. Fastenal,Macmaster Carr,Ebay no gots.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2023 at 9:12am
#9
Ford 345C TLB
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2023 at 10:37am
“..Does it have a part number or spec?..”
Measure the shaft diameter (not the groove), and that will tell you what the snap ring size should be. There is often a choice of ‘standard’ or ‘heavy (thicker)’.
If the bearings listed in an above post are correct, the shaft diameter is 40mm; so it will either be a 40mm ring, or maybe a 1-9/16”. Both are readily available from McMaster-Carr.
Edited by TramwayGuy - 31 Jul 2023 at 10:42am
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2023 at 8:07am
None standard thickness. Like 4mm. I got a part nu mber and found one at a dealer.
This page was generated in 0.280 seconds.
