B vs C vs CA
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Topic: B vs C vs CA
    Posted: 17 Oct 2010 at 10:16pm
It has always puzzeld me but what are the differences between the B, C, and the CA tractor. I've looked at several up close and even www.tractordata.com seems to point out that they are the same basic tractor with changes in front ends and seats.
I don't have any of the three but me and my friend were hoping you guys could help us out.
ALLIS-CHALMERS
RyanTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RyanTN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2010 at 10:26pm
Send me a PM with your email and I will send you a book called "The Little AC's".  It explains it all in some detail.  Offer goes for anyone.
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2010 at 10:55pm
The simple answer: Yes.
The real correct answer: Yes, but no
The 100% correct answer: Yes, up to a point.
The B and the C are basicly the same tractor, with the B set up as a 1 row tractor and the C being set up as a 2 row tractor. Early B's however have the BE 116 Cubic Inch Engine, while the later B's and (from what I have found and heard) all the C's had the CE 125 Cubic Inch Engine.
The CA was introduced and shared the same CE engine that the later B's and all C's had, but introduced a new transmission that had 4 forward gears, 1 reverse, a new, more powerful hydraulic system, a hand clutch for operation of the roto-baler and other equipment, and a new, redesigned torque tube that had 2 mounting holes in the middle for certain mounted implements. Later B's also featured this new torque tube. The CA also came out with the new traction booster system, and the pin hitch and (later) snap coupler implement mounting systems.
Hope this helps. Any more questions, feel free to ask.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 8:17am
The "Little AC's is a good read. Link to an On-Line copy of it is:
One can save a copy to your computor and print it out;
Post Options Post Options   Thanks (0) Thanks(0)   Quote RyanTN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 9:04am
Thanks for posting the link Greg!  I couldn't remember where I got it from.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 9:51am
The B being narrower that the C or CA for cultivating one row of a crop where the C was for cultivating two rows of a crop. The B has faster final gears than the C.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 9:55am
The CA stands for Cat's A^&.
A really fine tractor.
We used the C for cultivating 70 acres of potatoes for years.
Great two row tractor.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 10:29am
 If you are looking to buy a "B", "C" or "CA" I would go for the "CA".
 The "CA" is more like a small "WD". It has more HP than the "B" & "C", it has the same hydraulic system as the "WD" & "WD-45", 4 forward gears vs. the "B" & "C"s 3 forward gears and the "CA" has the power shift rear wheels.
 Also with the "CA"'s redesigned front and torque tube it is easier to mount the equipment.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 10:41am
Thanks for the link to the article , a good read  and worth downloading to keep
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 11:16am
 I did forget  the hand clutch.
   The "CA" came 3 ways;
1) with out a hand clutch.
2) with a hand clutch on the right side.
3) with a hand clutch on the left side.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 11:20am
I've heard the CA described as 2/3 of a WD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 11:42am
 I enjoy using mine very much. For a small tractor it does everything that I need and want it to do. It can pull a 3-14 8 inchs deep in sod has well as run a #90 All-Crop off the PTO. What more can I ask? For all that know me should be able to tell you that I don't baby my "CA" nor do I abuse it or miss state what I have or can do with my little old "CA".
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 12:05pm
And how wide is your SC disc Dennis? That little gal pullin' the disc always surprised me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 12:33pm
 I pull a 9 foot mounted disc.
Thanks & God Bless
Dennis
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 5:52pm
I have the 8' mounted disc and it pulls with relative ease. Really surprised me the first time I tried it. However those mounted discs IMO are pretty light weight discs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 6:28pm
 You should try the #40 mount disc if you really want some weight
Thanks & God Bless
Dennis
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2010 at 10:01pm
I like the duals on there Dennis. Gives her a nice attitude.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 12:26am
Is there a video of that CA pulling that disc?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 7:58am
WKPOOR, I don't know of any video and I think that is the only picture there is as well. The picture was taken at the AC Jamboree in Davis IL at Ted buiskers place. I was discing the ground that was just plowed. I think that was my 2nd pass over the field. If you look real close you can see that the lift chains on the disc are hanging down which means I am letting that disc dig as deep as it wants.
Thanks & God Bless
Dennis
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2010 at 5:56pm
Thank you Ryan for the heads up on the article, and Greg for the link. I had never seen that before. I've got it now!
are genuine." - Mark Twain
Florida Ryan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Florida Ryan Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2017 at 1:18pm
Is that link still valid?   Can't seem to get the article on the little ca's
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2017 at 2:39pm
I would like to know more about the fine points  of the engine .I got a B and had to file out  holes to match manifold , about one fourth inch to get CA carb on. Engine  surges at high idle but level of pulling.Adj gov rod and konw rpm are 1650 on a CA. Thank venture is bigger and wonder about in take mainifold.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RyanTN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2017 at 2:42pm
I got a couple of PMs about the little AC book today. I posted about the book seven years ago. I’ll need to dig around some old data sticks to see if I still have it, I’m pretty sure I do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2017 at 3:11pm
http://www.frontiernet.net/~garosier/Little%20ACs.pdf
it is a PDF, not a DOC.
Edited by steve(ill) - 15 Oct 2017 at 3:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote RyanTN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2017 at 3:14pm
Good link Steve! I found it in word format and sent it out too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2017 at 5:12pm
For pulling I matched the manifold ports to the head after reaming or boring out the head. What for pistons do you have in the B? There is difference in the manifold and head ports in size from the start in 1938.
This page was generated in 0.172 seconds.
