Xt turbo
Dkienzle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dkienzle Quote  Post ReplyReply Direct Link To This Post Topic: Xt turbo
    Posted: 27 Jun 2023 at 12:52am
Looking for a turbo, manifold and any oil lines off an 190 xt. Going to be going on a 185 so would like all the parts if possible. Pm me or call or txt 319 290 five 5 zero 7.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2023 at 5:45am
Any 180/185 I ever installed a turbo on, the turbo got positioned backwards on the exhaust manifold and then the exhaust pipe will come up thru the existing hole in the hood. Everything else will have to be fabbed up differently, but it looks very nice.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2023 at 5:55am
If you are going to have to fabricate stull (like DrAllis says), you might want to buy a new manifold and have someone like InjpumpEd recommend a better turbo than came stock on the 190XT.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2023 at 8:59am
I have a manifold, but nothing else to go with it. In central Ia.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dkienzle Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2023 at 9:31am
Thanks Dr, I will keep that in mind.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2023 at 3:45pm
You will need a larger air cleaner assembly and piping as well.  An oil cooler would be a good idea as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2023 at 6:23pm
Air cleaner size pretty much dictates how often you may have to service the filter. Any 180/185 I ever turbo'd never got an oil cooler or a different air cleaner. They were never a heavy use drawbar tractor, but a 90 HP PTO tractor. Change oil every 75 hrs.
festus51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2023 at 8:20pm
I'm pretty sure I have both
We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
This page was generated in 0.158 seconds.
