1939 B axle seal
acken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acken Quote  Post ReplyReply Direct Link To This Post Topic: 1939 B axle seal
    Posted: 26 Jun 2023 at 8:44pm
Is it possible to get outer axle seal replaced without disassembling final drive? This is splined axle, not flanged. Not sure what the purpose of seal spacer outside of axle seal is, and if I can pull it out. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2023 at 9:08pm
yes, you can pull the splined hub, then get the old seal out.. It will be a felt type seal.. New will be a rubber standard seal....  Seal does not ride on the SHAFT, it rides on a spacer that is pressed onto the shaft... You probably will not get that off.. When you tighten the  BIG NUT holding the spline hub to the shaft.. you squeeze the hub against the spacer, against the bearing inner race..
Edited by steve(ill) - 26 Jun 2023 at 9:10pm
