Parts supplier recommendation
CW2 Ryno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CW2 Ryno Quote  Post ReplyReply Direct Link To This Post Topic: Parts supplier recommendation
    Posted: 25 Jun 2023 at 4:16pm
Who do you all recommend for engine parts? Need a set of rings, head gasket set, carburetor kit, radiator hose and rod bearings for a D19 gas.
mike a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2023 at 4:50pm
steve fisher on this sight will prolly chime in
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2023 at 6:23pm
Got mine from Mark Pfouts on this site
Post Options Post Options   Thanks (0) Thanks(0)   Quote CW2 Ryno Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2023 at 7:43pm
I emailed Mark I believe, my list got longer as I started inspecting parts. Probably too much to put into it but I’ll know what I have when it’s back together.
Head gasket set
Rod bearings .010 under
Piston rings
Oil pan gasket
Carb kit
Dist cap
Rotor
Cap base
Plug wires
Water pump
Thermostat
Rad hoses
Rims/tires.
Head work
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2023 at 7:47pm
Do you have part numbers.
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2023 at 11:47am
can get or have most of what you are looking for thanks Steve
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2023 at 6:14pm
I would also be happy to help you with your needs.
