Well gonna HAVE to split the 180
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Well gonna HAVE to split the 180
    Posted: 25 Jun 2023 at 2:38pm
PTO Inner seal been leaking a long time, now the PTO has decided NOT gonna stay engaged and is Manual not Hydraulic.  Will undoubtedly need slider, shaft, maybe fork and seals.  Sucks.
This as I am scheduled to have Cubital Tunnel(Elbow) surgery on both arms sequentially, then IF Arthritis is not so bad, have a SI Joint Fusion performed.  Be down something like 8-10 WEEKS.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2023 at 5:04pm
I have fixed several manual PTO's on 180 tractors and it's always the same problem. The PTO lever linkage is poorly designed and weakly built and if anyone gets rough with it, things get bent/twisted. Then, the hand lever winds up hitting the back edge of the hood not getting the sliding coupler fully engaged. I generally start with draining the hydraulic and transmission oil. Remove the PTO shield and give the shaft a yank and remove it from the tractor. Dress the burred end of the removed PTO shaft with a grinder removing anything that would impede the coupler from engaging fully, mainly getting the end O.D. back down to size. Now, with the shaft removed, concentrate on the linkage. The curved lever directly behind the clutch pedal lower pivot shaft is usually twisted and coming in contact with the clutch pedal pivot area BEFORE it gets to the detent position inside the torque housing. So, now you have to determine if you can heat the lever to get it clocked back clockwise enough to get full engagement to the detent. Maybe your issue is the hand lever roll pin?? Maybe the mid-way bell crank?? Could be all three things, but until you get the inner sliding coupler to reach the detent position, it ain't gonna work right. Once you get the linkage stroking 100% stick the shaft back in and I think you'll be pleasantly surprised. Shift lightly from now on !!
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2023 at 5:17pm
Wow Doc you are priceless! (as we all already knew!)
Blue Skies and Tail Winds
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2023 at 5:25pm
If replacement parts are still available from AGCO, that lower PTO lever is twice as thick to prevent bending/twisting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB(wcIL) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2023 at 8:53pm
I was able to replace the coupler by dropping the PTO drive gear box under neath and I might have removed the power director plate cover on the side of a 185 I used to have.  It had the left-hand manual engagement and 540 only.  If I remember correctly, man the was probably the mid 90's.  Andy
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2023 at 8:59pm
Do as the Dr. says, but make a lever like the D17 has coming up along side of torque tube,and weld it to original linkage. Do away with the junk linkage the engineer made.                MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2023 at 9:54pm
Actually Mack, my high platform One-Seventy has the standard equipment PTO lever on it with a One-Eighty platform/seat arrangement. Works just fine !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2023 at 5:02am
My 180 was problematic as first bough, replaced shaft and coupler several years ago then made mistake let another borrow the tractor for a ditch needing mowed as could not get his 16’ batwing in it, I have a 8’ Bush Hog 3008. Been rough to deal with since so pulled the Bent shift rod and got it to go full detent yet can watch the shifter slop back out as de-throttle. Shaft likely worn to taper again from his beating into submission. Hydraulic oil has been migrating to trans/final for a few years, pushing more faster now so time for seals.
Appreciate all the suggestions, just has come to tear down as it also needs a clutch.
ClayP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClayP Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2025 at 3:09pm
Does anyone know the double seal part number on the 180 pto shaft between the transmission reservoir and the hydraulic reservoir? The National # is 50058, but my local parts stores can't seem to work with that number?? My a/c parts book isn't real clear on those two seals. Thanks in advance, Clay P.
Edited by ClayP - 28 Jun 2025 at 3:10pm
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2025 at 3:32am
I believe from a quick google the AC part # would be 235296 but would await someone with more experience to confirm. My main reason for reply was that if your local supplier can't handle a National seal number what are they doing?
Stuck Farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClayP Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2025 at 5:24am
Thanks, I'll check that number to see if it might work. I agree about my local dealers. The National #50058 seems to give them problems!
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2025 at 6:42am
Correct AGCO p/n is 70227679. It takes two seals. P/n might change to a Massey number from this number. Pack the first seal (rear) with grease so the spring won't pop out of place when you drive it into the bore. Brass bushing is inside of the first (rear) seal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2025 at 7:13am
I didn’t find 235296 in the 180 parts book.
Try 227679
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClayP Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2025 at 12:41pm
Thanks for all the help! Those two lower seals have been holding me back from sliding the 180 back together.
