New well at barn Friday |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35705 |
Topic: New well at barn FridayPosted: 24 Jun 2023 at 4:04pm |
Been awaiting this as was worrying with new wells all around the two springs up the valley may shut off. Drillers were completing as I returned from Town Friday so stopped in to see what was doing. All complete, were gathering up Cribbing and tools, 6' Mud Bit to Stone drill, 140-150' hit the white sand layer and water, drilled on to 340' for buffer as usual. As was speaking with driller he added the tablets they do after drill could hear plop plop as hit water, was only 7' below top of mud casing. Said was likely a better well than anyone else nearby has. Went down this morning to retrieve the 180, stump to pull and a few shrubs wife is done with, could hear running water. Well is Artesian.
Fitters will add drain line to creek pool behind barn for casing then set two hydrants, the surge tank and a Cattle waterer system, should not have a issue with water from now on!!!
Edited by DMiller - 24 Jun 2023 at 4:06pm |
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6621 |
Posted: 24 Jun 2023 at 7:04pm |
Looks like you made out good on that one.
DMiller
Posted: 24 Jun 2023 at 7:41pm |
Yes we did. And as dry as has been get two prizes, a damned fine well and a auto feed into the Creek pool the cows use daily.
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9733 |
Posted: 26 Jun 2023 at 5:09am |
Yes two prizes for sure. Can’t beat that deal. We’ve been dry this year too. |
DMiller
Posted: 26 Jun 2023 at 5:11am |
Field grass and clocer have returned to dormant, cows are walking the entire place in search of Green as well shade. MAY get some light rains by Wednesday, maybe.
