Cables, what lube are you using
notime View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote notime Quote  Post ReplyReply Direct Link To This Post Topic: Cables, what lube are you using
    Posted: 24 Jun 2023 at 8:35am
I'm installing a new clutch cable in a 7050 series. It feels dry. Should it be lubed for longer life or is dry better. What lube are you using. I was thinking atf but will it attract dust and make it worse.
What's your experience?
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2023 at 8:43am
Liquid graphite with a cable lube injector. It goes in as a liquid and leaves dry graphite powder behind. Injectors are available online, and at motorcycle shops. Many new "Morse" type cables have a nylon interior jacket and are marketed as not needing lubed, but it never hurts to relube them.
Edited by Codger - 24 Jun 2023 at 8:59am
That's All Folks!
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2023 at 8:44am
Leave them dry, any liquid lubricant will attract dust, and cause it to wear out faster. Now, if the calble is starting to cause problems, and I don't have the time to replace it right then, I will try to work some powdered graphite into the cable to get by.
Edited by bigal121892 - 26 Jun 2023 at 6:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2023 at 5:17pm
If that new clutch cable is of good quality, the clutch pedal will push easier than it did before !!! And it will last another 20 yrs or more too.
Edited by DrAllis - 25 Jun 2023 at 5:17pm
