D-15 Belt Pull Hydraulic Pump
hwstem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hwstem Quote  Post ReplyReply Direct Link To This Post Topic: D-15 Belt Pull Hydraulic Pump
    Posted: 23 Jun 2023 at 11:00am
My neighbor wants to add an optimal hydraulic pump for the belt pulley to his D-15 diesel. Are they available if so where at? And what needs to be done to do so?
Thank you in advance!
-Wade
1939, RC Allis, 1941, Farmall A, 2 1938 Silver King R-44's (to make one) 1953? Case SC (parts for sale) -"If you are going to do something, do it right"
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2023 at 1:57pm
Pretty sure belt pulley will stop when clutch is pushed in....
If so,depending on application, this could be a bad thing ??
Only way I know to get a true 'live' hydraulic pump, would be off the front of the the crankshaft.
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2023 at 2:10pm
Here's what I did
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2023 at 3:29pm
"Optimal" hydraulic pump?? how about "auxiliary" hydraulic pump ??  I know they made one for the D-17 and could have for the D-15 as well. A poor set-up at best. Only worked when your foot was off the clutch pedal. No parts available any more unless by chance you found a salvaged tractor with the optional hydraulic system. The home-made "live" system is by far superior or a front pump from an all-hydraulic loader is too.
rtwfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2023 at 5:31pm
Got a d15 d highcrop with side mounted pump. 402-469-1738
Edited by rtwfarm - 23 Jun 2023 at 5:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2023 at 5:40pm
So, it's more than just the pump, right ?? It has an oil tank on the right platform and some sort of a hydraulic valve stack ?? maybe on the left side beside the seat??
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2023 at 5:44pm
Call for pictures 402-469-1738
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2023 at 8:42pm
Pics sent
MadCow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2023 at 1:58pm
Originally posted by coggonobrien coggonobrien wrote:
Here's what I did
Kit? Parts list?
Edited by MadCow - 27 Aug 2023 at 1:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2023 at 3:25pm
This hydraulic system is a "one-of", utilizing a hydraulic pump from a Northern Hydraulics Catalog, making a pump mounting bracket that attaches to the thermostat housing, adding a second pulley to the crankshaft pulley and finally using a hydraulic console/valve stack from a D-17 IV or 170-175-180-185 tractor. All the hoses and connections were selected to get the installation completed on the D-15 II chassis in March of 2017. The original hydraulic sump is tapped into on the front left side corner for hydraulic oil supply and there is a return filter from a 180-190-200 under the left rear axle area to filter all return oil. The only time any hydraulic oil ever leaves the sump is when a one-way cylinder is extended, so a couple of quarts at the most. When using a 2-way cylinder extending, even less oil leaves the sump. It has performed flawlessly for 6+ years and is pretty neatly installed.
Edited by DrAllis - 27 Aug 2023 at 4:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2023 at 4:43pm
We have a D14 industrial with a pippin loader on it. It had a side pump. I don’t remember being bothered by having to make sure foot clutch was out. The center plate cracked and couldn’t find replacement so we put front pump on it
Edited by Mikez - 27 Aug 2023 at 4:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2023 at 5:08pm
As far as I know, any D-14/D-15 side pump was dead when the foot clutch pedal was depressed. Only the D-17 IV and One-Seventy's were "live" at that drive location.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2023 at 5:11pm
Guess what I meant was don’t remember it being a nuisance. Having shuttle clutch helps though
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2023 at 5:14pm
Edited by Mikez - 27 Aug 2023 at 5:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2023 at 11:09am
Here is the build thread for the d15 live hydraulic conversion.  I did all the fab work, Dr did the engineering.  Still works beautifully
