Allis Chalmers C 1944
Walter(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walter(MO) Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers C 1944
    Posted: 22 Jun 2023 at 5:11pm
What weight of oil should i use for the front spindle gear?
 There is a pipe plug in the front of the spindle housing.  Is that for draining the old oil?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2023 at 6:42pm
probably had 140 wt gear lube in the beginning.. With the lower seal 70 years old and hard, you will be lucky if it has anything in it.... Should be replaced, by many will pump grease into the cavity so the lower and upper bearing will get SOME lube..
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2023 at 8:22pm
Book wants 250 weight  but old seals won't hold it. I put a grease fitting there and filled it with grease, no leaks
