D17 Throttle friction washers
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Topic: D17 Throttle friction washers
    Posted: 21 Jun 2023 at 6:01pm
Do the throttle friction washers have a composite (like brake pads) or are they solid metal? The ones on our D17 IV located behind the dash are all metal and not sure if that is correct or not. If worn, any substitute available as they appear to be backordered on AGCO site, part no 70276996.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2023 at 6:02pm
They are plastic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2023 at 6:35pm
Plastic- ok, with all the grease on them I assumed they were metal with a glued on composite that was worn off.
I had throttle issues (linkage adjustment was required) and thought these were worn out.
Thank You
Edited by Stan R - 21 Jun 2023 at 6:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2023 at 6:41pm
In order for them to work with any degree of good performance, they must be left clean and dry. The only downside is when they get wet (from rain or power washing) rust forms on the slide plate and the lever will work a little stiff until the rust rubs off, then back to normal.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2023 at 5:52am
AGCO has them ready to ship          Also Agriteer in Waynesboro PA has two in stock  717-762-3093
