Allis 400 loader |
capn lonnie
Topic: Allis 400 loaderPosted: 21 Jun 2023 at 1:49pm |
So when I put hydraulic fluid in my loader, it ends up transferring into the main housing and leaking through the overflow, and my loader stops functioning… there is a loader pump that mounts below the rear PTO shaft..is there a seal that could be bad, causing the fluid transfer? If so how difficult to repair? Thanks!
'44 B '46 C '58 D-14 '78 5050
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7542 |
Posted: 21 Jun 2023 at 3:55pm |
Which tractor? The 400 series loader usually had its own hydraulic reservoir in the left side upright support that was completely separate from the tractor. |
capn lonnie
Posted: 21 Jun 2023 at 4:25pm |
Tractor is a 5050, and yes, the reservoir is in the support… the pump is mounted to the rear just under the PTO shaft
DrAllis
Posted: 21 Jun 2023 at 4:59pm |
Shaft seal on the pump. Pump shaft bearing/bushing may be bad. Might have to replace the whole pump.
capn lonnie
Posted: 21 Jun 2023 at 6:48pm |
Thanks, the pump seemed to be functioning properly with fluid, hopefully just the seal needs to be replaced
