D19 rim options
CW2 Ryno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CW2 Ryno Quote  Post ReplyReply Direct Link To This Post Topic: D19 rim options
    Posted: 20 Jun 2023 at 7:35pm
Aquired a D19 over the weekend that needs some attention, both rear rims are shot. What options are out there for alternate mounting to use a non spin out rim ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2023 at 9:54pm
D-19's came with 15.5 x 38 or 16.9 x 34/18.4 x 34 rear tires. All three could be power shift or non-spin out wheels. Changing from power shift to non-spin outs or vice versa only takes all the hardware. The cast wheel center remains the same. There are thousands of D-19/190/190XT/200 or 7000 and D-21 tractors in salvage yards to get your parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CW2 Ryno Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2023 at 10:30pm
Thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2023 at 5:29am
Just to make sure you don't mis-understand....there is a 34 inch cast center and a 38 inch cast center. Changing from power shift to non-power shift is only a hardware change. You cannot put a 38 inch rim on a 34 inch center and vice versa.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CW2 Ryno Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2023 at 11:19am
Current size is 18.4-34, I’ll double check dimensions before committing
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2023 at 11:49am
rtwfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2023 at 2:33pm
Got what you need. 402-469-1738
Post Options Post Options   Thanks (0) Thanks(0)   Quote CW2 Ryno Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2023 at 6:23pm
Thanks all!
