CA transmission fill question
MELCA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MELCA Quote  Post ReplyReply Direct Link To This Post Topic: CA transmission fill question
    Posted: 17 Jun 2023 at 9:03am
New member here with a quick question. I recently bought a 1952 CA and am working to get it running again. I think the transmission is filled through the dip stick port where tranny fluid is checked. Is that correct or am I overlooking something?
Grew up on a farm and we had gas 190s and an old Farmall H. Great forum.
Thanks
Ken Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken Mn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2023 at 10:12am
Yes you fill through the dipstick using a universal trans hydraulic oil. There are three drain plugs to get all the old fluid out. One under the transmission, one under the differential and one under the hydraulic pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2023 at 12:51pm
the transmission, differential gear , hydraulics are all combined into one oil cavity with 3 drains... as Ken said.
Edited by steve(ill) - 17 Jun 2023 at 12:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MELCA Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2023 at 6:28pm
Thanks much…
