200 Injector lower copper sealing washers
Bruce Nelson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bruce Nelson Quote  Post ReplyReply Direct Link To This Post Topic: 200 Injector lower copper sealing washers
    Posted: 12 Jun 2023 at 12:04pm
What works to remove the lower injector sealing washers. I removed the injectors and 3 washers stayed in the head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2023 at 6:06pm
A 5/8 tap, used to clean out bolt hole threads- get it down in there and turn it a few times then should pull out
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2023 at 12:08am
I've used a drill bit larger than hole for tip. Tap into washer and turn with a plier while pushing down.
