7040 low power issue
Allisguy93 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisguy93 Quote  Post ReplyReply Direct Link To This Post Topic: 7040 low power issue
    Posted: 11 Jun 2023 at 1:05pm
Hello all, new to the forum so please don’t laugh at me to much. So I have a 1976 7040 that I got from my father-in-law , the tractor has been repowered with a N6 combine motor long ago (1983 model I believe), it hasn’t ran in probably 5 years , I dug it out of its grave pulled the pump and injectors out and sent them off to a guy to have them gone threw , this tractor has the roosa master db2 pump I believe and Bosch injectors. Tractor in it’s day was around 250hp and I do remember it being very powerful and would hang with our newholland 8770 genisis   So to current time I have it running and have put several hours on it and it runs well and runs smooth but is very lack for power I’m thinking maybe around 90-100hp tops   Struggles to run a 15ft batwing in short grass , our other 7040 that is completely stock runs circles around it . I have redone the fuel system to a spin on filter and also has a small electric lift pump , checked and checked again and always have gobs of fuel to the pump , have messed with the timing gear and have it to where I believe it should be , tractor starts pretty well and does smoke and is responsive down lower in the rpm’s but as it gets higher like 1600+ it becomes less and less responsive and very laggy but continues to smoke like a train   And will work for you but just is nothing like it use to be .I’ve asked a lot of people about it and tried many of things but it has me at a total loss. Seems like the pump is just turned way down but from my understanding it can’t be turned up unless on a stand , I have the “torque” screw about all the way out and made no difference in power . I am no mechanic when it comes to injection pumps , Any help would be appreciated , thanks all
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2023 at 1:30pm
Which way is the return bolt on the injectors facing? My bet is you installed the injectors backwards. Return goes toward valve cover, but is more difficult to get return put on, so many people mistakenly turn them the other way. Problem is the holes come out the tip to accommodate the injector leaning in the head. Turn it a half turn and now the holes aren't spraying a flat pattern on top of piston. What does the pump shop say?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisguy93 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2023 at 2:50pm
I will double check them tomorrow morning when I get to the farm I didn’t think I could put them in backward cause I thought they had a groove in the head and a little tit on the Injectors but now you got me questioning myself . I haven’t reached out to the guy that went threw them for me , he’s not a allis guy but was nice enough to work on this stuff for me and I hate to complain about something not knowing if it even has anything to do with pump or injectors
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisguy93 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2023 at 3:35pm
Ok the suspense was killing me so I drove over there and sure enough you are right I have the return bolts on the bottom so I must have them in upside down I put them in same as our other 7040 with the allis injectors
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2023 at 4:41pm
AC injectors cannot be put in wrong, inlet on side prevents that error. Bosch injectors have no locating ball or notch to ensure they are properly installed in the head. One just needs to know the return bolt goes to the valve cover. I guarantee it'll run better with them installed the right way. I've seen this happen with IH and JI Case engines as well. It happens.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisguy93 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2023 at 4:57pm
The return bolt is definitely facing down so there the same way as our other tractor so backward. I must be thinking of the injectors that was in my Cummins engine that had the little ball idk. But thank you for the help I will pull them tomorrow and flip them around and post my results, much much appreciated
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2023 at 5:30pm
Just a thought,you might check your air filter system to be sure
no unwanted critters have the filter home and restricting air flow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisguy93 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2023 at 5:46pm
Kevin210 I have had it all part and been threw all the tubes and boots and filters ,turbo and intake also checked for intake manifold leaks with either and all to no avail , but thank you for input I think the problem lies in the Injectors and me having them backwards that makes sense as to why it’s acting the way it is , just frustrating that I didn’t know this sooner because I took pictures of all of it before I tore it apart and I thought I put it back the way it was but I’m thinking not now and there is no allis guys around me that k is anything like that
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2023 at 6:33pm
Do us all a favor and install a no more than 30 PSI gauge in the intake manifold and tell us how much turbo boost pressure it makes with the throttle WIDE OPEN and pulling hard down to 2300 RPM's. I got news for you....it NEVER had 250 HP.
Edited by DrAllis - 11 Jun 2023 at 6:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisguy93 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2023 at 7:14pm
Dr. Allis I have no idea how much power it really had just what I was told was around 250hp my father in-law said he pulled a 6 shank ripper pretty deep at 10 mph. He said that tractor was hot in it’s day   I don’t care if it’s only 150hp I just want it right and to at least keep up with our other one that’s stock and yes I can rig up a boost gauge was planning to do that anyway to figure out if I had a boost problem causing the lack of power , turbo is stock I think it’s a .96 ar is what housing says and it’s tight on in and out shaft play
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisguy93 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2023 at 7:17pm
I do remember when I was dating my wife probably 11-12 years ago now when he still farmed with some I pulled a 40ft Phillips harrow with it same one we usually pulled with the 7580
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2023 at 7:19pm
Good. You have one to compare it to. I'd expect about 14 psi max of turbo boost. Check the good one. Then, you'll know what you should have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisguy93 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2023 at 7:23pm
Pulled the Injectors, turned them around and stuck them back in today and she runs great! Haven’t worked it yet or got a boost guage on it but will try to tomorrow but acts 100% better. Thanks injectionpumpEd and everyone else that commented so far
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2023 at 8:07am
Let us know how it does. I'm sure you got your old tractor back now.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2023 at 8:25am
Originally posted by Allisguy93 Allisguy93 wrote:
Hello all, new to the forum so please don’t laugh at me to much. So I have a 1976 7040 that I got from my father-in-law , the tractor has been repowered with a N6 combine motor long ago (1983 model I believe) Tractor in it’s day was around 250hp and I do remember it being very powerful and would hang with our newholland 8770 genisis
Welcome to the AC forum. Congratulations on acquiring your FIL's 7040. Is it a 20speed Power Director or 12 speed Power Shift? A gleaner N6's 3750 670HI engine was 220hp stock. Applications for that engine were as follows; 7080, 7580, 4W220, N6. At 250hp, that engine's fuel has been increased 13.6%. Do you or your FIL remember any additional upgrades done during it's repowering? Larger size radiator for adequate cooling? Heavier duty clutch pressure plate?, etc.?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisguy93 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2023 at 8:41am
It is a 20 speed power director trans
It doesn’t have any upgrades done other than torque screw backed out that I know of   It got a new clutch and torque when motor was put in and the radiator was boiled out but Is the stock 7040 radiator
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2023 at 9:13am
Be careful there, I think combine engines were rated at flywheel hp so not a true comparison.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisguy93 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2023 at 9:36am
So we just took both 7040’s up to our local new holland dealer and ran them on there pto dyno. Mine with the n6 motor made a 120hp and 9psi of boost and our other one that’s stock engine made 160hp and 14psi so glad on the one and disappointed on mine acts like it isn’t getting enough fuel out of the pump or it’s just flat wore out but seems to run to good to be the case
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2023 at 10:08am
I think your pump needs put back on the test stand and corrected. No boost,no power. It's not delivering enough fuel.
Edited by SteveM C/IL - 14 Jun 2023 at 10:10am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisguy93 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2023 at 10:23am
Was my thought. I’m trying to contact the guy that went threw it for me. What do I have him set it at? I would like to have it at least 200 or better at the pto if it’s possible to do and still use it like a tractor and not completely get my butt kicked in a out the feild class to hook it in. A had an 8070 that was 230hp at the pto. Different motor I understand but was not hot or Smokey to use or use hard for that fact   This tractor will bushhog is the hardest it will get worked
Edited by Allisguy93 - 14 Jun 2023 at 10:39am
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2023 at 10:28am
You're probably right in thinking it's a fuel flow to the pump restriction. Happens all the time, people think they have injection pump issues, when it's a plumbing issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisguy93 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2023 at 10:41am
Ed do you think the in-line low psi lift pump i have in the line could be holding it back? I can’t remember how many psi it is , it’s been around along time and was on one of my 12v Cummins trucks. It’s probably 8-12psi if I was to guess
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2023 at 10:46am
I’m reading that you want to competition pull with it too? ….and brush hog.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisguy93 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2023 at 10:51am
No I don’t want to competition pull it. But we have a local pull with a straight out of the feild farm stock run what you brung class that we have put stuff in before but everyone and there brother bring there turned to the moon 1066 or 4320 and win. Just be nice to ruffle some feathers was all I would hope for
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2023 at 10:56am
Tomato tomato….ok, but pulling. Call it what you want
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2023 at 12:16pm
many people put on those little fuel pumps on these and it absolutely does restrict flow to the injection pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisguy93 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2023 at 12:22pm
Injpumped is there a way I can talk to you on the phone?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2023 at 8:05pm
Was your N6 engine belching any smoke while on the dyno?  Any blowby?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisguy93 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2023 at 8:27pm
Hardly any smoke out the stack at all   It does have some blow by. She is tired and I know it , but she isn’t shot . I think it’s in the pump somewhere checked the timing again and retimed it to dead on 18* pulled fuel lines and inspected. Took off lift pump and would not start without it , put it back on and rebled it and got it running messed with timing advance on pump after talking to pump guy and it’s almost all the way in and has a decent ping to it now so guessing it’s advanced pretty good, was the only way to make it not pop as it revs up but still a complete t**d and no smoke
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2023 at 9:06am
So correcting the injectors made it run better, but still a dog? You've got a serious issue if it won't start without the electric pump. The injection pump has it's own transfer pump inside. If it was properly rebuilt, it should be fine. I'd be questioning your pump shop. I never like to see someone go adjusting my pump settings. You may still have a plumbing on the tractor issue. Good luck!
