Flathead generator
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: Flathead generator
    Posted: 09 Jun 2023 at 10:38am
Fav son found an old generator buried in the dirt way back in the woods . Just curious as to what it came off ? Found 21 A 42    10139 on it , which seems to have been on a 1940ish Ford flathead car . Probably have pics up soon . Anyone have a clue ? Thanks !
WeisAC2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC2 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2023 at 12:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2023 at 12:33pm
There it is , looks like it's been buried a while . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2023 at 1:01pm
http://www.allfordparts.com/
again... click on this link and it will appear in the link bar at the top of the page... delete the %20 in the link and hit ENTER... you will be at the ALL FORDPARTS page.. go to page #7 for a drawing of the old generator............ and for some reason that site does NOT want to link... here is a screen shot..
Edited by steve(ill) - 09 Jun 2023 at 1:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2023 at 1:04pm
some parts are available....
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2023 at 1:18pm
type in "ford generator 21 A 42    10139" in the LINK BOX at top of the page and you will get a GOOGLE SEARCH of several sites... ( if you use GOOGLE).
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2023 at 1:25pm
Thanks Steve, good info. Sure would like to know how it got where it was. Maybe 🤔 someone was off roading? Always heard Uncle had a still back there years ago
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2023 at 5:52pm
Pulled generator apart and it has/had some kind of cloth inside ? What the heck was that for?? Thanks
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2023 at 8:22pm
The field coils were originally wrapped in a cloth material to insulate them from the body of the generator. It tends To come apart over time in conditions such as you found that one!
Edited by Alberta Phil - 11 Jun 2023 at 8:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2023 at 6:24am
The sad thing is I have TWO of them, in 'ok' condition in the garage attic......
they'll have to 'go to China' as I was told my stuff next door HAS to be removed...
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2023 at 7:08am
Thanks for the explanation Phil. Learn something every day.
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2023 at 12:23pm
That long mounting bracket allowed it to be moved up or down to adjust the tension on the V-belt that went around the crankshaft pulley, the water pumps on each side of the 'V' and the generator on the early flat head Ford engines. I had lots of first hand experience with these engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2023 at 12:31pm
Thanks Don. Been wondering about that.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2023 at 12:49pm
My first car was a 1953 Ford convertible with the flat head V8
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2023 at 1:01pm
Henry Ford was intelligent and frugal. The first V8 engines were largely based on the castings for the model A flat head four. One side was mounted at 45 degrees and the second side was essentially a mirror image of the model A casting mount 45 degrees the other way and offset by the thickness of a connecting rod.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2023 at 2:37pm
Interesting , Thanks Don !
This page was generated in 0.406 seconds.
