301 crankshaft
soggybottomboy View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote soggybottomboy Quote  Post ReplyReply Direct Link To This Post Topic: 301 crankshaft
    Posted: 08 Jun 2023 at 12:51pm
I have a crankshaft out of an Allis 301 diesel. I haven't had it speced out yet. If it turns out to be in good shape, what is it worth? The opinions so far range from $200 to $1500.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2023 at 1:31pm
There's at least 2 cranks for 301 CID engines. Knowing it's part number or what engine model number & serial number may help determine the value.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2023 at 9:10pm
Narrow gear or wide?                MACK
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote soggybottomboy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2023 at 9:09pm
It's out of an M2 combine engine. The serial # was hard to read, but looked like 109 thousand something. I don't know the difference between narrow and wide gears.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2023 at 9:21pm
First M-2 was 1977, so it would have the wide gear to be able to drive the crankshaft driven oil pump used first on the 200 tractor and later.
This page was generated in 0.049 seconds.
