allis chamlers 160 hyd.
John WV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John WV Quote  Post ReplyReply Direct Link To This Post Topic: allis chamlers 160 hyd.
    Posted: 08 Jun 2023 at 8:19am
well i have been working on my dad's 160 hyd. system  low pressure i clean all filters new pump and only got 800 psi on remote. check release spring but it looks good but it may be weak agco has  no new spring  cant even buy repair parts for the blocks .Can  somebody out there  tell me what to do? Dad brought this tractor new in 1970 i would love to keep her in working order and use it . the 3 point hitch will go up but very slow and only gos up at high rpm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2023 at 9:14pm
Are you sure you replaced the right pump?                   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2023 at 10:35pm
John is this the same issue you had last year?
Post Options Post Options   Thanks (0) Thanks(0)   Quote John WV Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2023 at 5:44am
ac720man sure is i work on it time to time i have done everything i could think of and the repair book said the hyd  system has been thought a lot  i don't think i can repair it no parts available said agco to repair the two blocks. the next time you come to winchester if you want to stop and see me iwill be glad to show you i'm 8 miles north on rt. 11 at state line near flying j  exit 324 thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote John WV Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2023 at 5:52am
ac720man is it dry down there?  no rain here since early may  only got half the hay this year today will finish first cutting .
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2023 at 7:28am
Are you 100% positive you have the air bled out of the system?   160’s can be a bear to bleed out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2023 at 8:12am
I agree, they can be difficult to get the air out. John tried my suggested procedure last year and apparently it didn’t help. It works every time for me when I change the oil/filter but for some reason it didn’t help John. If I remember correctly Mack suggested loosening the Allen head screw on the side of the valve body that sits on top of the pump? I’ve never tried that. Hopefully Mack will respond to verify.
John, sounds like I’m about 1 1/2 hours from you. PM me your cell info and I will jump on the Harley one day and come see you. It would be a pretty ride. Like to help you resolve the issue.
Edited by AC720Man - 10 Jun 2023 at 8:13am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2023 at 8:15am
And yes we are very dry. Production is way down for sure. If we don’t get some rain soon there won’t be a second cutting. We are officially in a drought here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John WV Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2023 at 11:09am
ac720man i put a new pump on last year everything was doing good was running haybine . then the next time i hooked up it would not lift the haybine head up until then everything was fine.  first thing i did was check relief spring i was going to put in another one but agco doesn't have them call all the dealers around here no body has one . So i have some free time  so i was going to work on it again. Like i said dad brought it new would like  to get it working . Now my other 160 all  i did was but on a new pump and have no trouble from it about 10 years ago
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2023 at 12:40pm
Any chance your only problem is bad "worn out" remote couplers on tractor  or haybine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote John WV Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2023 at 5:10pm
ky.allis, i never thought about couplers . haybine works ok on my other 160 thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2023 at 10:07pm
John, been a long day. I got your PM so I will give you a call next week.
Rob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2023 at 10:56pm
I know years ago, my 200 all of the sudden wouldn't lift a disc harrow. Finally put new  couplers on the tractor and  disc and it worked.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2023 at 11:04pm
I replaced mine as well Ky-Allis when I first bought mine. They were leaking but that’s a good recommendation. I always put Pioneer ball couplers on, 4155 if I remember correctly.
