4W305 Engine Overhaul Parts
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Topic: 4W305 Engine Overhaul Parts
    Posted: 05 Jun 2023 at 11:17pm
I read a while ago somewhere, that there was no longer a supplier for sleeves and piston kits for this engine, is that the situation?
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2023 at 5:45am
At one time I thought Ivan Sumerix was getting pistons made. Don’t know if he still has anything or not.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2023 at 10:38am
There was a post by amishdirect a while back about 25000 mark II heads and I talked to him. You might contact him he could give you insight
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2023 at 12:00pm
Wouldn’t it be the same as a 8550?
I think jensales might have an overhaul kit….
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2023 at 2:06pm
I noticed that JanSales kits(out-of-frame overhaul kit & piston kit) both state, “please call for availability.” On the other hand, some of that engine’s other kits state, “add to cart” like they’re readily available?
Here’s a link to it.
https://www.jensales.com/products/ep-915143-allis-buda-out-of-frame-overhaul-kit-allis-chalmers-6120t.html
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2023 at 4:28pm
Thanks.  From looking at the price listed for the kit I am now confident it's getting a different engine, most likely an 11.1 liter detroit
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2023 at 9:24pm
I never like “repowers” in rare tractors because it ruins the tractor…
Like the 855 Cummins repower in the 8550s, it ruined the looks.
It’s only my personal thoughts so don’t mind me, it your tractor…
I’ve always like the intake manifold that says Allis Chalmers…
Edited by 55allis - 11 Jun 2023 at 9:26pm
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2023 at 3:18am
Try Phil hunt parts,tamworth australia,he has a lot of NOS parts.He was also getting liners made for certain engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2023 at 1:30pm
I guess I never asked, what is going on with the tractor?
Is it just burning some engine oil or is it something more serious?
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2023 at 6:58pm
I totally agree with 55allis. It's your tractor and you can do whatever you choose to do. If I was fortunate enough to own a rare tractor like this I would search every corner of the earth to find what I needed to keep it original. Just my 2 cents. Ryan
MikeKroupa View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeKroupa Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2023 at 9:50pm
You could also maybe find a good 6138T (844 ci) and use that for your repower engine, been done many times and still all AC. The pistons are the hardest part to find for the 6120T, sleeves are the same as the 6138. Good Luck, Mike
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2023 at 8:36pm
Injector tip broke, piston pounded the pieces a bunch of times, have not pulled the an yet, but she had a massif knock going on idling into the barn. I need this tractor to work for me, engine has over 3000 hrs on it, just since coming to my place alone. and has been using more oil than in the past the last few years.  i think any change I can make to make my equipment more reliable, more efficient and do  better job is worth the effort.  the rest of the tractor is in very good condition, newer tires as well
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2023 at 8:43pm
I know a guy that has some heads if you need one. Ill put you together if you want
Donald Matthews
910 824 8856
Leave a message if I dont answer
1984 80780
1957 D14
616 tractor
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2023 at 9:20pm
Thanks,  I have one more engine to get out of my shop before I start into the 305.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2023 at 7:34am
I have a 4W series service manual that I would sell, if interested.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2023 at 8:30pm
Heitmans tractor might be able to help, but it’s in Wisconsin so I don’t know how it would work crossing the border…. I can give you his phone number if you want it, just let me know.
From your description it’s a possible savable engine as long as it didn’t smash the block, my thoughts are “if it runs, it’s savable”.
I have a 45D that wasn’t timed right and the valves hit the pistons right after an overhaul but it didn’t ruin them and it still runs good after setting the timing right…
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2023 at 6:38am
I have done lots of business with Mark over the years
Thanks Lynn, I have a service manual for every tractor I own(ed)
ajl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ajl Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2023 at 11:19pm
I also hope you can keep it Allis since it is a rare 305.   I have run an 8550 when it rolled over the 10000 hr mark and it was running good at those hours.   Granted I was pulling a 50' Degelman land roller at the time so it was not under heavy load.
This page was generated in 0.297 seconds.
