D15 Pulling Power
John-Paul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John-Paul Quote  Post ReplyReply Direct Link To This Post Topic: D15 Pulling Power
    Posted: 03 Jun 2023 at 7:29am
What do you think, would my D15 have the power to pull a 6' dual blade land grader with rippers? I would be grading after a rain - the road does have some hills. I'm just wondering if 6' may be too big for the horse power? Thank you!
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2023 at 7:34am
Just a guess but I think it should fairly easily.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2023 at 10:16pm
What’s he HP requirement of the dual grader? It’s a 46hp tractor, ours handles a single 6’ with extensions easily.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John-Paul Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2023 at 10:30pm
Yes, good question. I just looked up a manufacturer, Land Pride, and for both a 6' and 7' they recommend 40-90 hp. So spec-wise and experience-wise, it sounds like the D15 should be able to handle it then. Thanks for the feedback!
modirt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2023 at 7:18am
Snap coupler or factory 3 point?
D15 I'm stewarding had the factory 3 point and the main casting that holds it all together had been busted and welded at least twice before I came along. I had it welded the 3rd time. Concluded the casting and design was not robust enough for any serious work, so I converted the factory 3 point back to a snap coupler......more of a hybrid between the two. Drawbar will handle it, the factory 3 point arms still suspect.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2023 at 1:37pm
As far as the D15 3 pt, dad bought ours new in 1968. It’s done a lot of plowing, 3 pt equipment, tillage and we have never had any issue with the 3 pt. Abuse can break any tractor IMO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2023 at 2:08pm
Tha biggest problem that the D-15 had was when operators used it like it was a D-17 or larger tractor. Any sensible operator will soon realize the limitations of his machine and will use it appropriately. Yes operator error has a lot to do with most machines demise. I have a series 2 D15 and I love it , nimble enough to get around and strong enough to get something done. Like modirt says the factory 3 pt is more like a Ford 8n or 9n. Use it carefully and you shouldn't have any issues.
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2023 at 8:05am
Most likely but it would also depend on how hard the ground is.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2023 at 9:25am
I was always one that tried my best to match a tractor to job task at hand. And that goes both ways, not to small of a tractor for a job, and not an over large tractor for a low hp task.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John-Paul Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2023 at 8:22am
All good considerations. Pays to be wise. I plan to keep using my '63 for another 10-20 years. Thank you!
