8030 FWA axle leak
Northern Hoser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Topic: 8030 FWA axle leak
    Posted: 02 Jun 2023 at 7:54pm
Hi all, axle stub leaking on the front as seen in the pic, axle has some movement so guessing bearing is on the way out ...which bearing and seal is it in the diagram?
I'd like to preorder the parts but scratching my head as to which ones they are
Thanks
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2023 at 8:26pm
16 is the bearing. 17 is the “housing”. 18-19 are seals and 20 is the o ring for the bearing housing
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2023 at 9:30pm
Awesome thanks, does that bearing housing come out with the axle? Looks like it's got a clip on the inside
Matt
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2023 at 9:35pm
It will if you remove the screw #13.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2023 at 7:31am
Are you sure your bearing is going out?     My 8050 axle was leaking someone suggested I clean the breather and I did it doesn’t puke anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2023 at 7:44am
Thanks for the replies, I'll look at the breather again, I put a new O-Ring on it last fall could be clogged up I suppose, thanks for the suggestion.
Planting all done in these parts so have a bit of down time to get some work done on it; getting the air conditioning up and running shortly
Matt
