Brake rod |
DCAC
Joined: 20 Oct 2018 Location: east central SD Points: 529 |
Topic: Brake rodPosted: 01 Jun 2023 at 7:03pm |
Looking for a good used or NOS brake rod for a Series 4 D17, part number 237331, only need one, but might take a couple if someone has them. Not sure how this one got broken, but the hook end is missing on the left one,
200Tom1
Posted: 01 Jun 2023 at 9:42pm |
I broke one several years ago. You might want to look, my memory is bad, I think the left and right were different. But please check that out. Like I said memory is like burnt toast.
DCAC
Posted: 01 Jun 2023 at 9:53pm |
I wondered if they were different as well, checked my parts book, and according to that, they are the same.
DCAC
Posted: 01 Jun 2023 at 9:55pm |
Thanks for the advice 200Tom1,
Jasonw
Posted: 02 Jun 2023 at 7:07am |
They are still available from Agco, about $55 per rod.
DrAllis
Posted: 02 Jun 2023 at 10:16am |
The hook on the end is where they usually did break. You can cut it off a little run a 3/8" die up on the remaining rod 2 inches and get a 3/8" threaded yoke to screw on in place of the broken hook.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 02 Jun 2023 at 9:21pm |
AGCO has new ones
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2483 |
Posted: 02 Jun 2023 at 9:48pm |
The way that the Dr. describes is better, stronger, and provides an easier way to adjust the brake.
DCAC
Thanks(1)
Posted: 02 Jun 2023 at 10:05pm |
Many thanks for all the replies, Gentlemen! I hadn't checked with AGCO when I put this post up, was kind of a spur of the moment decision, and had originally thought of fixing it like the Good Doctor suggested. I thought I'd check with you all on here before proceeding with that. I did buy a 3/8" threaded hardware hook and threaded coupler, and that's how I'll go for now. I can order a new rod if this doesn't work. Thanks again, everyone!
