FRONT WEIGHT |
SIMPLICITY
Joined: 19 Sep 2009 Location: ERATH LOUISIANA Points: 521 |
Topic: FRONT WEIGHTPosted: 31 May 2023 at 7:09pm |
DOES ANY ONE KNOW IF THE BIG SQ,CASTED U SHAPE WEIGHT WITH 2 BOLT HOLES WILL FIT THE FRONT OF A 185 ? ALSO IS THERE A SPECIFIC NAME FOT THAT WEIGHT?
Darb210
Posted: 31 May 2023 at 7:25pm |
if it is the one im thinking of then yes it will. starter weight or chin weight is what they are normally called. can stack smaller slabs outward on also
SIMPLICITY
Posted: 31 May 2023 at 7:27pm |
YES I THINK YOU ARE RIGHT
Unit3
Posted: 02 Jun 2023 at 9:04am |
How many tractors did the "U" shaped or starter weight work on?
DrAllis
Posted: 02 Jun 2023 at 9:09am |
170-early 175-180-185-190-190XT-200 and I think the 210-220 also used the same weight even tho the side frames were wider.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8987 |
Posted: 02 Jun 2023 at 1:34pm |
yes they narrowed the front hsg on 220 to accept the starter wt
