1949 C distributor
Fxdx0175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fxdx0175 Quote  Post ReplyReply Direct Link To This Post Topic: 1949 C distributor
    Posted: 26 May 2023 at 6:52am
I've been told so many different things about the distributor/ magneto.    I want to replace the mag with a distributor, what will work?
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2023 at 7:09am
 I believe it would.
 I would go to an Allis Chalmers Dealer to get it, then you would get one that would fit.
Mfam8 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mfam8 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2023 at 8:50am
Yes, it will work, but you will need the correct drive and housing along with the distributor itself. I sent you a PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2023 at 8:52am
when you remove the MAG, you notice that it is not a gear drive.. It has TWO TANGS that drive the shaft... That is what you are looking for.. Something off a B, C, CA will all work... looks like this on e-bay.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mfam8 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2023 at 9:01am
Steve above has listed ONE way to do it, you also can do it with another setup. Steve has listed the magneto conversion style, there also a factory setup with an extended drive gear setup that was used on CA's and a similar setup on d14/d15
Image result for CA allis distributor
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2023 at 9:05am
   i  have to ask why ?  did your mag quit?  you will have to rewire  your tractor
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mfam8 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2023 at 9:09am
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2023 at 1:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2023 at 9:02pm
We offer a Mag to distributor conversion kit. Gives you everything you need to do the deed except ambition. New wiring, key switch, choice of coils (6 or 12v) new spark plug wires, plugs, installation instructions, rebuilt drive, rebuilt Distributor top to bottom. Available with points or with electronic ignition. Visit our website. Our P/N's- 1511B-01 points version, 1511B-02 Electronic ignition.
Steve@B&B
bb-customcircuits.com
