Wc magneto - fires on all ports
kevin LA-CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevin LA-CA Quote  Post ReplyReply Direct Link To This Post Topic: Wc magneto - fires on all ports
    Posted: 25 May 2023 at 10:17pm
Last fall the wc wouldnt start. No spark. Took off the magneto cleaned up the points and got spark. Doing some testing found it was sparking on all ports no matter where the rotor was.
Tried cleaning up cap and rotor, but no change.
Conventional FBM of the 1940s - not sure the full number. Any suggestion? Or just a new cap?
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2023 at 11:28am
There has to be some serious carbon tracking inside the cap to enable the current to flow to all 'ports' at once.
I would replace both cap and rotor.
