7045 Seat?
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Topic: 7045 Seat?
    Posted: 25 May 2023 at 12:22pm
What have people done for a new seat? Agco? Am I the only one who thinks Grammer”s website sucks? There’s a number to call Grammer, I’ll do that but looking for suggestions please.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2023 at 2:09pm
I use K & M manufacturing
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2023 at 5:30pm
WHICH SEAT ???  That "luxury seat" was fairly nice when it was brand new, but the suspension was short lived and difficult to fix. I've even had to weld broken frames. The standard seat was pretty much the same suspension apparatus as a 1957 D-17. New shock/springs are available. New linkage bushings are available. All from DJS in Michigan.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2023 at 6:00pm
The basic seat I normally put in new brass bushings and get the seat recovered.
If its lasted 30-40 years already, another 20 and I'll be done.
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2023 at 7:36pm
It’s not the luxury seat. It’s pretty much toast. I was hoping for some sort of upgrade that can work fairly easily.
Leadoff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leadoff Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2023 at 9:58pm
Tbone95
Here is a link to previous seat discussion from this Forum that might help you
I have seen some 7000 Series Tractors fitted with the Milsco Seat ( shown on the 185 and 200 cab pic).  Please note the support frame discussion/pics later in the discussion
As Dr Allis has noted, the Allis Chalmers standard seat frame/support parts/mechanism goes back to the D17 Series I.
The Milsco Seat is an exact match to original Allis Chalmers seat (if ordered/supplied that model of seat).  Milsco (Milwaukee Seat Co) was a supplier to AC.  The only source for the seat is Serco Loaders, Two Harbours, Minnesota.  Their Dealers Network can supply the seat
Good luck with your project
1963 D17D Series III. 1965 D15 Series II. 1965 D17 Series IV. 1975 185. 1978 716H. 1979 716H. 1965 780 Harvester/1R&DC. 1957 Model 73 SC 4 Furrow Plow
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leadoff Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2023 at 10:17pm
Tbone95
Another Forum discussion ......rebuild the suspension on a 200 standard seat assembly, which might be similar to your 7045..........excellent pics near end of thread
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2023 at 7:18pm
PUT AN AIR RIDE FROM K & M BEST THING I'VE EVER DONE SAVED MY BACK !!!!!!
