Complete HD5A disassembled and parting out. Low ti
rehpig View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rehpig Quote  Post ReplyReply Direct Link To This Post Topic: Complete HD5A disassembled and parting out. Low ti
    Posted: 25 May 2023 at 8:36am
I have dissembled my HD5A tug. This was a factory tug used to move machinery/ tooling around indoors. It has very low time a wear. I am utilizing some of the undercarriage but the rest is for sale. My phone number is +12482314838 and would gladly talk to you about your needs. I have a walk around video of the unit running prior to disassembly. Complete engine with clutch assembly attached. All internal gears appear like new. This unit was used indoor it’s whole life and never saw sand or dirt. The track grousers are rubber and disassembled from the backer plates. Btw. All but three of the over 200 nuts/bolts came off and are reusable. If you ever wanted to use your unit to be in a parade these are your ticket to participate. Radiator is original (as best I can tell) and clean. Has original paint on it. Has a little “fan blades to close” but dry and clean. Housing in good shape. Do not have the front grill as the front had a extremely heavy plate with a 4” thick steel weight/push block. The parts are all palletized. Let me know what you need. Rhead78@att.net
This page was generated in 0.049 seconds.
