Disc harrow drag?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Disc harrow drag?
    Posted: 22 May 2023 at 9:50pm
What is the best brand of the spring tooth harrow drags? I used my new to me  100 series 6 1/2 foot snap coupler disc. Man that things really cuts. Would like it to level better. It needs a lot of work, but it gets the job done. Thanks, Tracy
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2023 at 9:54pm
Tracy, I had a IHC 13'. It did a great job as long as you weren't moving 2 fast.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2023 at 8:10am
A rig like that, they’re all pretty much the same. We had one you could lift with hydraulics, that was pretty handy if you were getting stuck or needed to back up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2023 at 5:07pm
You might want to improvise something to pull behind the disc.  I used to use a hunk of I-beam, about a foot wider than the disc...Wink
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2023 at 6:08am
Don't think brand on that matters much. Important thing thing is what teeth you have on it and how you use it. I used a brillian with duck feet. Could run it shallow and not pull up a lot of rocks. When i first had it, it had narrow teeth and i ran it too deep. Still picking all the rocks it dragged up
This page was generated in 0.130 seconds.
