unstyled wc questions.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: unstyled wc questions.
    Posted: 16 Oct 2010 at 8:39pm
I just bought a wc today at an auction in OK. It has cast iron (not spoked) front wheels are these ac or somthing else (#71466 1937 I believe). It has pto and a power lift. What is the correct rear tire size (24" solid wheels)? And were all unstyled wc's distilate tractors?
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2010 at 8:44pm
I believe the spoker rears on the unstyled WC's were 10" x 24", if that helps.
are genuine." - Mark Twain
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2010 at 8:52pm
That serial would make it a 1938 and would have had the 24" one piece steel wheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2010 at 8:54pm
Here is a link to the discussion we had a week ago about the unstyled that I brought home.  According to your serial number, you should have disc rear rims on it.   I have a set here, but we're worlds away.   They only used them for a year or two?  I think.   I can't find my book with all the WC differences right now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2010 at 8:58pm
Yes it is the 24" one piece rear wheels I would like to know what size of 24" rear tire is correct? It has grader tires on it right now. And are the solid cast 5 bolt front wheels original? They seem like wheel weight wheels.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2010 at 9:02pm
11.25X24 is what they were back then. When you say solid cast wheels I start thinking wheels off of a Speed Patrol which would explain the grader tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2010 at 9:08pm
Put a pic on here of the cast wheels.   They could be Case rims.   They fit on allis five bolt hubs.
Larry in OK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in OK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2010 at 11:11pm
I found out after you let that the rear tires were probably bought used from the county.
Have you tried to take the front tire "slippers" off yet?
Some people are like Slinkies. Not really good for much of anything but they still bring a smile to your face when you push them down a flight of stairs.
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2010 at 8:47am
they are probably right if it is a 38 becuz i used to have one but i traded for a 37.,
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2010 at 9:24am
Sounds like WC speed patrol front wheels to me too. I guess the speed patrol didn't have the 5 bolt pattern.
Edited by CTuckerNWIL - 17 Oct 2010 at 12:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2010 at 9:28am
An 11.25-24 tire back then is a 14.9-24 in today's numbers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2010 at 10:50am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2010 at 11:02am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2010 at 11:09am
You got me, I don't know what those front wheels are?? They almost look like some industrial type.
Mike Sanwald View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Sanwald Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2010 at 11:55am
Those are front rims off a CASE SC. I put them on mine if I need extra weight on my WC pulling tractor. Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2010 at 4:43pm
Mike wins the cupie doll, SC Case. I don't know what they weigh, but they are heavy!
