Loader won’t go down on my d17
jonnyd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jonnyd Quote  Post ReplyReply Direct Link To This Post Topic: Loader won’t go down on my d17
    Posted: 22 May 2023 at 9:09am
I plowed my garden a few weeks ago and everything worked great but yesterday when I started the tractor the loader lift arms went up even with the lever in the down position. Could the traction booster lever have anything to do with it? I noticed that it was in the up position for some reason.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2023 at 11:43am
A properly adjusted Traction Booster lever if positioned all the way up as far as it can go, will raise the lift arms all the way to the top. So, the lever should be fully DOWN horizontal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jonnyd Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2023 at 4:32pm
That’s what I thought.I normally don’t mess with the traction booster lever but I must have inadvertently put the lever up.could this have made a valve stick somewhere?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2023 at 4:42pm
If you put the TBoost lever UP as far as it will go, the lift arms will raise fully and CANNOT be lowered. So, put the lever horizontal and see if it fixes your problem.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2023 at 8:13am
Wait, are you talking about a LOADER or the rear lift arms? Your OP says “loader lift arms”
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2023 at 8:58am
I experienced this when I was using the loader to push downed trees. A bolt in the TB lingage on the WD fell out raising the loader to it’s max.
