615 diesel metering valve info? |
nickia
Joined: 11 Sep 2009 Location: alden iowa Points: 793 |
Topic: 615 diesel metering valve info?Posted: 21 May 2023 at 9:11pm |
I have a 615 4 cyl diesel it has been sitting for 3 yrs I drained the fuel replaced the filter im not getting any fuel up to the injectors I cracked the lines no fuel I can hear the solenoid on top of the pump click when the key is powered up. would the metering valve be my problem? Location of this valve and can it be cleaned?
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8981 |
Posted: 21 May 2023 at 9:16pm |
I think if it's a Roosa you can unstick the metering valve buy removing top of pump but I don't know the particulars. Some knowledgeable person will have your answer.
MACK
Posted: 21 May 2023 at 9:28pm |
Metering valve can be freed by removing top of pump, but if pumping plungers are stuck, that is a complete tear down. MACK
nickia
Posted: 21 May 2023 at 9:39pm |
take off the top cover and I assume its a threaded screw? remove and replace at the same thread count? thanks
nickia
Posted: 21 May 2023 at 9:46pm |
found it I googled the pump found a break down of it
