D 12 back to life ?
Tyee II View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tyee II Quote  Post ReplyReply Direct Link To This Post Topic: D 12 back to life ?
    Posted: 21 May 2023 at 8:40am
Have a 1962 D 12 that has been in storage for years. Very good original condition tractor. Have had it running, needs carb cleaning/rebuild. Hydraulic lifts strong, the arms are stiff when lowering. Have been taking them up and pulling down. Seem s to be a bit less resistance each time. Is this a lift cylinder issue or possibly in the spool valve ?  Snap Coupler with Traction Control.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2023 at 9:01am
If there is no weight on the arms, it might just be old dry packing on the cylinder rod that is dragging... Might help to spray a few drops of penetrant on the extended shaft before you raise back up.
