Tire pressure? |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8987 |
Topic: Tire pressure?Posted: 18 May 2023 at 3:16pm |
What do you all run for air pressure in 18.4 radial singles? Has fluid. Were at 20. Even at 24 they squat plenty. Usually has duals. But removed for liquid side dress. Firestone R1 23 deg. One 2 inch inner wt each side. 8070 TIA
Edited by SteveM C/IL - 18 May 2023 at 3:17pm |
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90868 |
Posted: 18 May 2023 at 4:12pm |
steve(ill)
Posted: 18 May 2023 at 4:13pm |
cwhit
Joined: 12 Sep 2009 Location: Sigel IL Points: 1020 |
Posted: 18 May 2023 at 6:01pm |
7045 at 15,500 lbs sidedressing I’m at 20
SteveM C/IL
Posted: 18 May 2023 at 10:39pm |
At 20 singled out they looked like they bulged 4in in sidewall and had about 2 1/2 feet of tread on the ground. I went to 24 and the lugs on the ground are touching all the way to the outer edge. That's what the tire guy told me they should do when I bought them.
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1347 |
Posted: 19 May 2023 at 9:44am |
On my brothers 7060 (with duals) we run in the field at 12-15 psi but when we run a 5 shank 3 point subsoiler we run 24 psi to keep it from working the sidewalls.
Now my dad has a John Deere 4255 that he sprays with singles and we run about 25 psi or 3 lugs on the ground… |
