AC 7580 lower driveshaft U joint (knuckle)
tjwb71 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjwb71 Quote  Post ReplyReply Direct Link To This Post Topic: AC 7580 lower driveshaft U joint (knuckle)
    Posted: 17 May 2023 at 12:47am
Curious anyone know were could locate a U joint (knuckle) for lower drive shaft on AC 7580. Not having much luck finding new or used. Open to having one made if any shops I could contact.
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 5:57am
I assume for old style?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjwb71 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2023 at 3:02pm
Correct, but that being said was able to locate a salvaged drive shaft with joints so I'm good to go for now. Thanks. Don't really need shaft but it's worth grabbing whole thing for the joints.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2023 at 6:15pm
Couldnt a truck shop put you modern knuckles and joints on the original drive shaft ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjwb71 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2023 at 5:20pm
When I got chance was going to stop at driveline shop and see about getting some spar parts.
