185 power director
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Topic: 185 power director
    Posted: 13 May 2023 at 9:59pm
Should I be able to blow air out the hole in the bottom of the housing that has the transmission input shaft seal when hooking air up to the pressure lines? I tried it once with the original steel rings on it and then with another set, both times I had air blowing out that hole. I don't want to put it back together if something needs attention there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2023 at 5:55am
That bearing retainer casting is new?? or you're trying to reuse it ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2023 at 7:09am
Reusing the original
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2023 at 7:13am
Generally.....a BAD idea. It's not an air tight connection, but they always have some wear inside where the sealing rings go and if it is re-used, it will never run as many hours as a new one. Be sure the oil seal isn't pressed clear into the bottom....only flush at the top.
Edited by DrAllis - 14 May 2023 at 7:18am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2023 at 9:04pm
If there is much ware in housing, it will start breaking ends off sealing rings.                            MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2023 at 9:29pm
I had another one on a shelf with very little wear that I swapped out. I assume they are a smooth bore when new? This one still leaked some air but no where near as bad as the original.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2023 at 9:48pm
Absolutely a straight thru hole when new.
